condensing boiler primary secondary piping
bob eck
Member Posts: 930
anyone using the Caleffi Hydrolink for primary secondary piping. <a href="http://www.caleffi.us/en_US/Technical_brochures/01084/01084.pdf">http://www.caleffi.us/en_US/Technical_brochures/01084/01084.pdf</a>
if you are not using this what are you using?
I have been ....
making my own. Actually I had Lee @ www.earthlee.com make these up for me. She took down the specs and had them out w/in a week. Nice work. I add a 1.5" cap w/ a good hy-vent, add some screening inside and then go w/ a 1.5 x 1/2 coupling on the bottom. She will even paint them to you liking.0 -
Hydronic Separator
I use them and Taco's version as well. I quit doing primary secondary over 5 years ago when the light came on and I discovered the wonderful world of hydronic separators. Saves a crap load of piping and labor.0 -
Hydraulic Seperators
Rule.
There's never an argument on the spacing of closely spaced tees.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 73 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 851 Plumbing
- 5.8K Radiant Heating
- 375 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 27 Recall Announcements
