TRV adaptors
Gordan
Gordan Member Posts: 886
Does anyone know of a reasonably priced solution for adapting Danfoss RA2000 heads to M30x1.5 threaded TRV bodies? Danfoss' own 013G1360 goes for a pint of beer overseas, but here is apparently worth its weight in gold - that is, if you can even get it...
  • Paul Pollets
    Paul Pollets Member Posts: 3,671
    Oventrop
    Oventrop makes 2 stylesof heads, the HD and LD. One fits on the ring, one fits the longer throated valve body or Buderus wall panel radiators. The DiaNorm radiators use the ring-style TRV head.
  • Gordan
    Yep...
    I'm pretty sure some of the older Honeywell heads are m30x1.5 too (T100), but I'd rather use an adaptor than buy whole new gear...
