skimming new boiler
laxman
Member Posts: 8
Is it possible to skim a new install in 40 minutes?
Skimming time
That sounds short to me. The initial simmer with arm&hammer washing soda would take that long, followed by the actual skimming, for several hours.
Of course, this is something which is done by many here themselves, after the installer has done his piping, etc.
Does the water in the glass look clean?--NBC0 -
yes no maybe
I would say yes it is possible to skim a boiler for 40 minutes. Is that long enough? Probably not. You might as well learn how to skim it yourself. That way it can be skimmed to your satisfaction. Now that you have a new boiler, your new boiler is going to steam clean all the pipes in the entire house, and all that crap is going to end up in your brand new boiler. Show us a few pictures of your new boiler and we might be able to help you with "how to"0 -
40 minutes
I'm not a pro but it took me well over 20 hours to skim my boiler. I had to do it 6 different times a few hours each. Every time the system ran for a few weeks more oil washed down.
Many guys say cold skimming works fine but I felt the hotter the water the better it skimmed. It seemed like when it was just below boiling is when I got the most oil out. I believe the water churns some while it is heating, but as soon as you shut the burners off it settles down and skims really nice.
Again, I'm not a pro and have only skimmed ONE boiler in my life time and it was a learning experience. There are many many people on here with infinitely more experience than me. I just wanted to mention my experience as it may help.
Remember, a clean boiler is a happy boiler!Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
