whats the reason
taz
taz Member Posts: 13
Why would i have to keep hitting the reset on my 8184 control?
  • billtwocase
    billtwocase Member Posts: 2,384
    far too many to list
    I would start with a servicing if it has been a year or more. That should eliminate most of the common causes
  • taz
    what could be the cause?
    Was completely serviced 4 months ago
  • icesailor
    icesailor Member Posts: 7,260
    One Reason:
    The number one reason I have found is that the control doesn't "see" a flame.
  • Steve_152
    Steve_152 Member Posts: 26
    8184 resets
    plugged  pump strainer  &   or  filter=   restricted fuel supply =  crappy flame=  safety shutdown..as it should.
  • icesailor
    More reasons:
    No spark, poor spark, grounding spark, ad nauseum.
  • R Mannino
    R Mannino Member Posts: 441
    Restricted
    filter and or strainer caused by running out of oil.
  • billtwocase
    I would
    start by calling back the service personnel. You shouldn't have to trouble shoot for them either. If they are not qualified, then, check on here for a contractor near you. Not all problems can be resolved one stop, but anything and everything should be tested and checked.
