Honeywell wireless for Taco ZVC
Bill_89-2
Member Posts: 2
Greetings,
I apologise for what might seem like a dumb question.
I am designing a system using a Taco ZVC404 panel that will activate 4 valves in a manifold.
Of the various options available, it has been recommended that I can use the Honeywell system. However, I am confused about how this hooks up to the Taco panel.
If I use the Wireless Zoning Adapter Kit, YTH6320R1023, for zone control it seems to me that the Adapter will only work with the Honeywell TrueZONE panel, not the Taco ZVC404.
So, I get something like this:
Thermostat -> Wireless adapter -> TrueZONE panel -> valves
Can this happen?
Thermostat -> Wireless adapter ->Taco ZVC404 -> valves
If I use the Wireless thermostat kit, it seems that I need one kit for each zone, as the Equipment Interface Module only seems to handle one zone.
Thermostat -> EIM -> Taco -> valve
Times four?
Neither the Honeywell literature nor the Taco literature makes this clear, unless I am not too smart or I am missing something obvious.
Any insight would be appreciated.
TIA,
Bill
Can this happen?
Times four?
TIA,
Bill
Honeywell Wireless W/ Taco Zone Valves:
I did something like this in an antique brick house that needed to have radiant zones split and no way to run thermostat wires. I used the Honeywell Wireless controller and wireless thermostats that fed to a Taco ZV 503. I needed a wireless connection from the third floor to the cellar and no one made a wireless connector, Honeywell or Taco. I was told to use a Rib Wireless Relay but it didn't transmit any farther than the floor below. Possibly because of the copper coils plastered in the ceiling. But the Honeywell Wireless had no problem. I ended up finding a way to run a wire to the boiler.
What you want to do is very doable.0
- 86.8K THE MAIN WALL
- 56 Biomass
- 108 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 69 Pipe Deterioration
- 959 Plumbing
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
