Monitor boiler parts
TMorg
Member Posts: 23
I need a pressure switch for a monitor MZ40c boiler. Anybody still have parts? Or know of who bought all the parts?
Anything
special about the pressure switch?0 -
not really that I can think of
I picked up a spare Monitor MZ C boiler from Hot Rod, and got to talk to him for a minute or two. From what I can remember the switches are fairly standard vacuum switches, I would think that a universal replacement style would do the job, but would not fit in the same spot, if it was the big metal part. If you got one of the small plastic adjustable ones you should be good to go. Most switches have an audible "click" when they close, is this one closing? You may have try to make it prove without the inducer to figure it out, as the inducer on mine always had a loud whine.
I would offer to sell you my spare, but then again, that's why I bought the spare boiler from Hot Rod, I didn't want to be without parts in an emergency.
Good luck0 -
monitor parts
you might want to contact : Nelson & Small on canco rd. in portland, me. / they are, or at least were the northern new england distributor for monitor & toyo stoves..water heaters ..etc.. / may still have parts for your need../ good luck..0 -
monitor parts
Nelson Small
I heard that Nelson Small bought up all of the Monitor parts when they closed out some of their lines. I know that they did for the Monitor Space Heaters.
Good Luck.0 -
For parts
Northern Heating in Wasilla Alaska has a fair parts selection. 907-376-75150 -
HEATWIZ
For the best technical support, as well as THE place to purchase Monitor Boiler parts, contact Budny Fuel Oil/RPS at 1-800-597-6484. or email them at budny@budnyfuel.com. Ask for Rob.0
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 161 Indoor-Air Quality
- 71 Pipe Deterioration
- 999 Plumbing
- 393 Solar
- 55 Water Quality
- 46 Industry Classes
