peerless pinnacle
Pete_36
Member Posts: 19
Does peerless still sell the pinnacle. I know it was a rebadged munchkin. They dont sell the munchkin anymore but they still have the pinnacle? Any thoughts,
Peerless
Does anyone know of a way to get ahold of some sort of tech support for Peerless boilers?
I have a PI-140 that is giving me fits. It lights off then drops out, lights off, then drops out.
The flame signal prior to dropping out exceeds 4.0. I have checked all grounds and am unsure what I am missing.
My Minnesota Rep, of which I left a message with (36 hours ago) has not returned my call of yet, assuming they are quite busy with the cold snap we have here.
Any info is GREATLY appreciated!0 -
fault codes
Are you getting any fault codes. Have you checked out the heat exchanger and burner? I believe the Peerless is a Munchkin in a green container so follow the Munchkin service procedures. If the heat exchanger hasn't been cleaned lately, it probably needs it and its a good time to check the burner. Here is a recent thread about that: http://www.heatinghelp.com/forum-thread/139512/The-Munchkin-80m-walk-of-shame0 -
Peerless Pinnicle:
Peerless Pinnicle is an Irish Munchkin.
I'm sure it is to old to have the 926 controller.
It hasn't been serviced properly since installed. It will need a thorough cleaning and repair. It will need the drain cleaned, a target wall, door refractory and a new burner tube because the old one is probably cracked.
It's not something that a homeowner can easily do.
Where do you live?0 -
Peerless
Do you live in the Minneapolis/St Paul area?0 -
Thanks
Thanks for info, It has been a few yrs since I have been out in the field personally and now have the opportunity again.
I know exactly what you are talking about in regards to cleaning hx and drainage system. The thing I totally forgot about was the screws on the burner and cleaning them to provide a path for proper rectification.
Thanks for the help again!!
PS. I work in the Mankato area.0
- 110 Chimneys & Flues
- 982 Plumbing
- 387 Solar
