Whistling boiler
ToddB
I've just recently noticed, in the past day, that my Lennox boiler whistles briefly (10 to 15 seconds) after firing. It is from the boiler and not the main vents. Any ideas what this could be?
Whistle
is this an atmospheric burner?
my old american standard boiler used to whistle [for a few seconds] when the gas began to flow. however my new peerless atmospheric does not. this may have been due to a gas pressure, or air-mix problem.
see if you can pinpoint the exact location of the whistle using a length of hose one end of which is placed against your ear, and the other end pointing to various parts of the boiler.--nbc0 -
Thanks
Thank you. I have been concerned that this whistling was indicative of a serious problem. The boiler and system are operating as usual despite this new noise.0 -
adjust the fire rate very slightly
I've had atmospheric Weil Mclains that do this. A small adjustment of the pressuretrol or firing rate will avoid the gas flow hitting a resonant frequency, which is the whistling you are hearing. Of course, a change in the supply pressure may bring that whistling back down the road.0 -
Lennox Conservator
I'm not sure if it is atmospheric or not. It is a Lennox Conservator series installed by the previous owner in 1994. I will check the manual when I am home. Based upon what I am hearing I will have the burners checked.0 -
Lennox Conservator
uhm.. a Lennox Conservator is an induced draft boiler. Is it possible the "whistling" has something to do with either the draft blower or a restricted vent?0 -
Mine whistles, too.
My Weil-McLain whistles constantly while the gas is flowing. A plumber once told me the regulator (?) was too small for the flowrate, or the flow was too high for the regulator. It doesn't bother me anymore, I always know when the boiler is firing!0
