end switch for zone valve v8043
Joseph_4
Joseph_4 Member Posts: 319
Hi,
Does anyone know where to buy an endswitch for Honeywell V8043 Zone valve
or maybe a part number.
Thanks
Joe
  • ChasMan
    ChasMan Member Posts: 474
    Honeywell End Switch.
    Here are part numbers / UPC etc. For Zone Valves amde after 1978. If it is pre-1978. I would buy a lottery ticket.
    V8043 Series Zone Valves
    Item
    End Switch for Valves
    SKUs
    2HDC1, HON272744B, 272744B
    UPC
    085267123143
    Weight
    0.15
  • Joseph_4
    Do You know where I can buy the part?
    Thanks for the part number, my plumbing supply doesn't sell it. do you know where I can buy it?
    Thanks
    Joe
  • ChasMan
    Granger
    Granger among others, Bing that SKU / part number, there are a few places.
  • billtwocase
    billtwocase Member Posts: 2,384
    I've gotten them
    thru Sid Harvey. Might be best to replace the motor also. Those usually go before the end switches
  • Slimpickins
    Slimpickins Member Posts: 359
    end switch
    Usually its the linkage that engages the end switch that wears out. In my 20+ years I only tried to replace one end switch and what a hassle that was only to discover the linkage was bad. If you have the old 4 screw zone valve, buy a complete new zone valve and replace the plunger plate with your new 2 screw zone valve plunger assembly and attach the new head to it. If you have the newer 2 screw style, just buy the replacement head.
  • Paul Fredricks_3
    Paul Fredricks_3 Member Posts: 1,556
    I'm with Slim
    Why deal with the end switch. It is a pain.
    Unless you have a lo of free time. If you have a lot of extra time, go for it. if you have a lot of extra money, send it to me :)
  • Joseph_4
    Thanks for the info
    As always, Heating help comes through in the clutch. thanks for all your responses
    joe
