end switch for zone valve v8043
Joseph_4
Member Posts: 320
Hi,
Does anyone know where to buy an endswitch for Honeywell V8043 Zone valve
or maybe a part number.
Joe
Joe
Honeywell End Switch.
Here are part numbers / UPC etc. For Zone Valves amde after 1978. If it is pre-1978. I would buy a lottery ticket.
V8043 Series Zone Valves
Item
End Switch for Valves
SKUs
2HDC1, HON272744B, 272744B
UPC
085267123143
Weight
0.150 -
Do You know where I can buy the part?
Thanks for the part number, my plumbing supply doesn't sell it. do you know where I can buy it?
Joe0 -
Granger
Granger among others, Bing that SKU / part number, there are a few places.0 -
I've gotten them
thru Sid Harvey. Might be best to replace the motor also. Those usually go before the end switches0 -
end switch
Usually its the linkage that engages the end switch that wears out. In my 20+ years I only tried to replace one end switch and what a hassle that was only to discover the linkage was bad. If you have the old 4 screw zone valve, buy a complete new zone valve and replace the plunger plate with your new 2 screw zone valve plunger assembly and attach the new head to it. If you have the newer 2 screw style, just buy the replacement head.0 -
I'm with Slim
Why deal with the end switch. It is a pain.
Unless you have a lo of free time. If you have a lot of extra time, go for it. if you have a lot of extra money, send it to me
Thanks for the info
As always, Heating help comes through in the clutch. thanks for all your responses
joe0
- 87.5K THE MAIN WALL
- 122 Chimneys & Flues
- 118 Geothermal
- 15.9K Strictly Steam
- 57 Water Quality
