Propress or Xpress
James Day_2
Member Posts: 191
I found several posts from a few years ago on the different style fittings. I just purchased the Ridgid press tool and wondering which fitting to stock. Just wanted some more recent opinions. The xpress seems to be quite a bit cheaper. Is the quality that much different or are they pretty close. Thanks, James
Propress
James-
We are a stocking Distributor and realigned about a year ago to stock only Viega Propress fittings. I have some guys who swear by only using the Viega, part of the reason we consolidated. The price isn't terribly different from what I am seeing- obviously we won't discuss specifics so we stay inline with Forum rules. Ridgid and Viega are going to call the whole solution Propress- make your choice on Marketing Hype.
Bottom line- I used Propress in my house for water and for some of my gas.
hope that helps
TK0 -
A supplier
Used to stock both and I used them interchangeably for a couple years with no issue. Apollo and Nibco have ads for pressfittings,but I've. Never seen them in person0 -
propress
Do you Need the compact kit to connect the propress fittings directly to baseboard or will the 330b fit inside to make the crimp?0 -
Pro-press
I sell both the Viega fittings and use the X-press as a back up. I've seen other manufacturers product of press fittings too. Bar none the Viega is still the best in quality and customer support. Apollo only makes the pro-press ball valves. The reason the X-Press is cheaper is well.....I shouldn't have to answer that. Ya get what you pay for. The Viega XL-C in the 2-1/2 - 4" is a tad cheaper than the XL fitting. The XL-C is a wrought fitting while the XL is a heavier duty cast fitting and shorter radius than the XL-C. From 1/2" to 2" they're all wrought.0 -
Viega or elkhart Apollo xpress
As far as the get what you pay for in the xpress comment. I am a Apollo Xpress rep and the xpress has more leak paths for safety than the viega and it is less because it is priced economically to the market . The technology is exactly the same. If it wasnt you couldnt use the same tool. I am also a licensed master plumber in several states0 -
G-Press
I have started using G-Press from Tyco/Grinnell. It is exactly like Viega. I used the Express product and had a massive failure. Their leak path did not work. My guy forgot to crimp the joint and the system passed the air test anyway. 3 weeks later...it gives way and I have a major insurance claim. So thank for that Apollo guy!
Viega Is too expensive. I am buying G-Press for @ 7-10% less. I also buy my Groove products from Grinnell too.
James
JBK Heating0 -
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
