Hot water requirement for 24 unit multifamily
We manage a 24 Unit multifamily that we want to convert to gas. As part of that we will be removing the hot water production from the steam boiler and onto separate hot water heaters during the summer. Looking for opinions on how big of storage tanks we should have in place.
Will two 100 gallon gas heaters in parallel be enough for a 24 unit building with 11 two-bedrooms 8 one-bedrooms and 5 studios with medium to high hot water usage?
  • Jim Pompetti
    Jim Pompetti Member Posts: 552
    Hot water
    Also need , number of dish washers ,Baths , Is there a laundry ,if so how many ?
  • Haviara
    Haviara Posts: 30
    No laundry room
    Thanks for the quick reply.
    There is no laundry room or dishwashers.
    Each apartment has one bathroom with standard low flow shower heads. The problem however is that I have caught a few people swapping the shower heads and also using the bath tub to wash clothing. In general I feel that most in the building are not very conservation minded.
  • Ironman
    Ironman Member Posts: 7,903
    I Would Recommend...
    That you look at a modular mod/con setup like Buderus or Triangle Tube offers. Connect those to properly sized reverse indirect (s) and you'll have the most efficient system that will never run out of hot water.
    The boiler or indirect rep have programs that will properly size what you need.
    Bob Boan
  • Is_solar
    Is_solar Member Posts: 10
    Do solar
    Look into getting a solar, pre-heat system. Youll get  tax credits and other tax benefits and it would be great PR for your building.
