Thursdays emergency steam boiler replacement
gerry gill
gerry gill Member Posts: 3,084
went very well. Steve and the boys rock.
gwgillplumbingandheating.com
    Steamhead Member Posts: 18,499
    Looks great!
    any "before" pics? What caused the old one to fail?
    Consulting
  • gerry gill
    They didn't take any before pictures
    but it was that gasketed boiler thats so popular and the gaskets were toast..there was a literal river running across the floor to the drain..they were adding water every couple hours..no underground returns or anything..we put on a digital vxt so we can see whats going on..my gut says it was just time for the gaskets to go..around here we usually see the gaskets give it up around twenty one years..sad..but at least the replacement has cast iron push nipples.
  • SchenleySeven
    SchenleySeven Member Posts: 27
    2 pressure controllers
    Noob questions- why two pressure controls?
    Is the gauge 0-30 or something smaller?
    Thanks.
    One pipe steam, Weil-McLain 380 , pipes mostly insulated, 32 radiators!
    Bock 32E water heater, Bock M-SR burner with .75 80A nozzle.
  • gerry gill
    the gauge is the standard
    0-30 that comes with the boiler..and the pressuretrol is acting as a feeder interrupter switch, the power does weird things around here, and there is a magical voltage that causes the circuit boards to feed..crappy overhead power lines..the true limit switch is the vaporstat.
  • MikeyB
    MikeyB Member Posts: 696
    Boiler
    Great work Gerry, is your connection tying into the Bull of the Tee on the existing main? do you see any conflict there w/steam entering the bull?
  • gerry gill
    note in this case,
    as the takeoff is going out at 3'' and that tee is 4''..works well in this system.
  • MikeyB
    Boiler
    I see the bushing now, thanks Gerry
