Freewatt questions
Sal Santamaura
Member Posts: 544
I posted this in the "Defective Generator" thread but, in case it gets lost there, decided to start a new dedicated thread so anyone with Freewatt experience will see it. The Freewatt hydronic package looks attractive. However, there are some aspects that bear further inquiry:
<strong>* </strong>What mod/con is it, which HX is used and how has overall reliability/performance been? How compatible is it with various pumping/control strategies?
<strong>* </strong>A "typical" engine run time is stated as 4,000 hours
per year. What time-between-overhaul has the single-cylinder Honda
engine been exhibiting? What's the overhaul cost when required?
<strong>* </strong>There doesn't seem to be a combustion air input pipe
for the Honda engine. That implies it runs off room air. If one must
degrade a home's thermal envelope to provide ambient air communication
with the outdoors for a basement / mechanical room, what's the point of
the sealed combustion mod/con or trying to squeeze out every bit of
efficiency using this system?
Interesting concept, but I wonder whether it's cost-effective when all
these factors are considered. Any Wallies have experience with Freewatt
and able to answer the questions? Thanks in advance.
<a href="http://www.heatinghelp.com/forum-reply/1251716/Freewatt-questions">Reply</a>
<a href="http://www.heatinghelp.com/forum-edit-post/1251716/Freewatt-questions">Edit</a>
for the numbers
to work out I think you would need a constant use for the thermal energy it produces. Yes you may have a DHW load year around, but not enough heat load, to use the thermal energy produced causes the numbers to slip.
I don't know about noise, longevity of "combustion" air. I don't hear or see a lot of these running in actual conditions? Looks like the list doesn't either.
hrBob "hot rod" Rohr
Living the hydronic dream0
