cleaning hofffman 41 vents
da88510
Member Posts: 1
Can a hoffman vent be cleaned and reused. Will it work and stop hissing
Vinegar
Try boiling it in vinegar. That usually helps get rid of the crud.Retired and loving it.0 -
how long to boil?
Boil for how much time?
Same for all other radiator vents?
Same time for hoffman main vents?
I shouldn't boil a gorton #2, right or wrong?
Thank you, DaveOne pipe steam, Weil-McLain 380 , pipes mostly insulated, 32 radiators!
Bock 32E water heater, Bock M-SR burner with .75 80A nozzle.0 -
too much pressure?
Is his vent hissing because the boiler pressure is too high?One pipe steam, Weil-McLain 380 , pipes mostly insulated, 32 radiators!
No set time.
Just try it until it's clean. I'd boil them all.Retired and loving it.0
