cleaning hofffman 41 vents
da88510
da88510 Member Posts: 1
Can a hoffman vent be cleaned and reused. Will it work and stop hissing
  • DanHolohan
    DanHolohan Member, Moderator, Administrator Posts: 16,686
    Vinegar
    Try boiling it in vinegar. That usually helps get rid of the crud.
    Retired and loving it.
  • SchenleySeven
    SchenleySeven Member Posts: 27
    how long to boil?
    Boil for how much time?
    Same for all other radiator vents?
    Same time for hoffman main vents?
    I shouldn't boil a gorton #2, right or wrong?
    Thank you, Dave
    One pipe steam, Weil-McLain 380 , pipes mostly insulated, 32 radiators!
    Bock 32E water heater, Bock M-SR burner with .75 80A nozzle.
  • SchenleySeven
    too much pressure?
    Is his vent hissing because the boiler pressure is too high?
  • DanHolohan
    No set time.
    Just try it until it's clean. I'd boil them all.
