Wireless glitch
DanHolohan
Member, Moderator, Administrator Posts: 16,638
Here's an interesting story from the U.K.
<a href="http://www.bbc.co.uk/news/uk-england-hampshire-16354487">http://www.bbc.co.uk/news/uk-england-hampshire-16354487</a>
Retired and loving it.
wireless
I had a remote starter put in the wifes mini-van a few years ago, and was playing around with a function that makes the lights flash while at a mall parking lot. The sliding door of a mini-van next to ours opened up. Oops. I waited for a while and no one came, so I closed it. So much for security.0 -
nothing new
Years ago we had two way radios in the vans. I went to a house for a service call and no one was home. I keyed the radio to call dispatch and the garage door opened. I looked around, but no sign of a car. Keying the mic again closed the door.0 -
My girlfreind sells garage doors close to
a military base. Every once in a while they run there cummuications scrambler and it causes unprecedented havoc with garage doors. Some doors randomly open and close while others don't work at all. One guy came home and hit the button to open his door and the neighbors door opened and his stayed closed.0 -
Not just wireless
But line interference can occur on digital thermostats also.
I just recently had a no heat call on one zone , but the rest of the house was ok, this one zone is controlled by Tekmar Tn4 setpoint control. After a phone call to Tekmar we theorized that since the contol is located in the mechanical room along with all the audio-video equipment, and electric, that interference could have occurred , but not affect the other communicating thermostats. Just rechecked settings and powered on/off and it started working again by itself.0 -
Death by X10...
I purchased and installed an X10 wireless camera set up so I could be in the mountains, even when I am NOT in the mountains. One slight problem...
Whenever the camera is on, none of my other wireless equipment (cell phones, wireless land lines and wireless PC communications) works until I shut the camera sender unit off..
I suspect there are wireless cameras in the vicinity of these problems. I eventually switches to a wired type of Pan Tilt Zoom camera, and have not suffered an outage since. Recently, the digital converter on my PTZ decided to quit working, so I hooked the wireless unit back up to make sure it wasn't something else, and everything wireless dies when it is on, again, still...
Big brother is watching you :-)
ME0
- 111 Chimneys & Flues
- 106 Geothermal
- 978 Plumbing
- 387 Solar
- 45 Industry Classes
