Anti-freeze
Joeyjr
Member Posts: 11
What is the easiest, quickest way to check the anti-freeze in a heating system?
refractometer
use a refractometer.
also a automotive antifreeze tester will get you close. but they are for ethylene glycol.
heating system should have propylene glycol.0 -
Refractometers:
And most Refractometers will do both kinds of anti-freeze and lead acid batteries.0
