Anti-freeze
Joeyjr
Member Posts: 11
What is the easiest, quickest way to check the anti-freeze in a heating system?
refractometer
use a refractometer.
also a automotive antifreeze tester will get you close. but they are for ethylene glycol.
heating system should have propylene glycol.0 -
Refractometers:
And most Refractometers will do both kinds of anti-freeze and lead acid batteries.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
