One for the (really) Old Timers!
croydoncorgi
Member Posts: 83
Visiting relatives near Toronto, I find they have an incredibly old warm-air furnace in their recently-purchased house. It has obviously had additions over the years (a humidifier and an A/C coil in the Return air duct, at least, plus possibly a non-standard gas valve).
However, it seems to still be working - maybe as well as it ever did! All it definitely needed was a new fan drive belt. In general, it looks fine. The Home Inspector reported it as 'about 25 years old' but OK.
Furnace is a Roberts Gordon GL100-A. Gas valve is White Rogers 36C03. As far as I can discover, Roberts Gordon stopped making this model in 1969!
Anyone remember anything about this furnace?
I'm thinking maybe at least a smoke test of the heat-exchanger would be good idea. But of course I'm from UK and like a fish out of water in Canada. Where would I get a smoke cartridge in Hamilton, Ontario!!??
I'm in Ontario
While I'm not in Hamilton, I can suggest some wholesalers that may be able to help:
I'd suggest starting with the local Woseley branch:
Hamilton
123 Dartnall Road
Hamilton, Ontario, L8W 3N1
Tel.: 905-573-5100
You could also try:
Noble Supply
601 Burlington Street East, Unit B
Hamilton, ON
L8L 4J5
Tel: 905-570-1099
http://www.noble.ca/locations/hamilton
Hope this helps!0 -
Old
From my memory Roberts Gordon made conversion burners not furnaces. The White Rogers valve is probably not original to that burner.There was an error rendering this rich post.
I used to know the answer
To that, but now, I'm such an old timer I can't remember;)0 -
REAL Roberts Gordon thru & thru
The data plate is mounted on the casing of the furnace (inside) and is definitely showing the company name, the type (as above) and a serial number (starting 65, which might be a bit of a clue!).
The burner system is an unusual design, consisting of an injector, a horizontal mixing tube / venturi, a right-angle bend upwards and a round burner, with the pilot assembly beside it. Definitely could not be separated from the rest of the machine.0 -
Too old?
Luckily not too old to have a sense of humor!--nbc0 -
Sounds like
Sounds like a plane old upshot conversion burner to me. Installed lots of themThere was an error rendering this rich post.
What you have is a
Roberts Gordon up-shot atmospheric conversion burner. Many of these were powerpile self generating systems so if you had a power failure you could operate on gravity. I will have to look up that White Rodgers gas valve to see if it is a powerpile valve?0 -
If that valve is a
36C03U-333 or -433 it is a powerpile gas valve.0 -
Thanks
Good to hear from you, Timmy..
Hope all goes well in RI0 -
Things are going great
here in the smallest state. We may be small but we have big plans. I hope you are well. Have a Merry Christmas.0 -
Re: Roberts Gordon
Most of those were powerpipe 750 MV but there were some 24 volt units. We had the last of the old ceramic pie plate difusers for those burners up to about 5 yrs ago and finally used the last one. No longer to be had. When the crack and break apart the burner is done. They were pretty reliable albeit not too effiicient.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 48 Industry Classes
- 15 Recall Announcements
