Buderus control
I am installing a Buderus GB142-45 condensing boiler. I also got a logamatic 2107 control. Can I use this control with this boiler? I also have a SM300 indirect HWT with a separate coil so I can install solar panels at some latter time which will need a control to communicate with the boiler. Again can I use this control? I am kind of confused as to how this control communicates with the GB142.
  • Ironman
    Ironman Member Posts: 7,888
    edited December 2011
    Not Compatible
    The 2107 is designed to operate with Buderus cast iron boilers. It is not compatible with any thing else or another brand.
    The Gb142 comes with an AM10 outdoor reset control. To integrate solar, you need the RC35 control, plus an SM10 solar card.
    Bob Boan
  • PwswbwBuderus
    PwswbwBuderus Member Posts: 2
    pwswbw11buderus
    Thanks so much for that info
