Warren Webster trap?
Jeff Elston
Member Posts: 289
Webster
I have read other threads where others have recomended http://www.tunstall-inc.com/?s=webster0 -
out of business- sorry
Like Crash said, use a tunstall or a barnes and jones repair kit.gwgillplumbingandheating.com
Thank you
Any tips on Identifying the trap ?
I didn't see and other markings.0 -
I Hope for You
that the numbers are on the body somewhere underneath all that paint. It may be something like "533"
Is that trap being used to drip a large steam main perhaps?All Steamed Up, Inc.
https://heatinghelp.com/find-a-contractor/detail/all-steamed-up-inc0 -
trap is on Radiator
It is a bank building in center city Philly. A train wreck ,,, the trap is on a radiator its a warren Webster system the boiler was sitting at 5psi when i got there the water was squirting out of the vents ! steel hammers were doing there thing. Paint was thick. thanks again0 -
The number should be on the trap body
somewhere...usually on the side you can't get to.
It may be a 7 series trap.
Yeah, 5 psi is not enough...if they want to MOVE the building. 500 psi would do it.
5 oz/in2 is all that's needed to HEAT that building.
Were the squirting vents on the radiators perhaps?All Steamed Up, Inc.
