Warren Webster trap?
Are these still available? Or a replacement?
  • crash2009
    crash2009 Posts: 1,478
    Webster
    I have read other threads where others have recomended  http://www.tunstall-inc.com/?s=webster
  • gerry gill
    gerry gill Posts: 3,084
    out of business- sorry
    Like Crash said, use a tunstall or a barnes and jones repair kit.
    gwgillplumbingandheating.com
  • Thank you
    Any tips on Identifying the trap ?
    I didn't see and other markings.
  • Gordo
    Gordo Posts: 857
    I Hope for You
    that the numbers are on the body somewhere underneath all that paint.  It may be something like "533"
    Is that trap being used to drip a large steam main perhaps?
    Hydrolevel VXT Fanboy
  • trap is on Radiator
    It is a bank building in center city Philly.  A train wreck ,,, the trap is on a radiator its a warren Webster system the boiler was sitting at 5psi when i got there the water was squirting out of the vents !  steel hammers were doing there thing.   Paint was thick. thanks again
  • Gordo
    Gordo Posts: 857
    The number should be on the trap body
    somewhere...usually on the side you can't get to.
    It may be a 7 series trap.
    Yeah, 5 psi is not enough...if they want to MOVE the building.  500 psi would do it.
    5 oz/in2 is all that's needed to HEAT that building.
    Were the squirting vents on the radiators perhaps?
