Leaking Low Water Make-up Valve
Has anyone had an issue with the McDonnell Miller 51S makeup water valve? I am involved in a situation where the body of the valve is leaking water. I suspect the bellows has failed.
  • Abracadabra
    yep
    Yep.  I've seen that happen. Basically have to replace the entire cast iron head mechanism assembly with the bellows.  The bellows are not a seperate replaceable item. IIRC, the head also comes with a new float.
