Snowmelt
Mpj
Mpj Member Posts: 109
I have maybe just inherited a snow melt system. The tubes are buried deep in the cement. Four circuits in the basement. No sensor installed in the pavers.
I am looking for some type of add on sensor to make the system turn on automatically come the snow fall. I spoke to Tekmar and they had nothing for me except to core drill and add a sensor.
Anybody have a product that can be installed outside, maybe next to the slab or something?
Thanks for the help.
  • Mark Eatherton
    Mark Eatherton Member Posts: 5,875
    Options...
    ETI makes a nice remote snow switch.
    http://www.heatizon.com/files/activation/M326-Instructions.pdf
    HeatTimer use to have one that monitored the supply and return lines (constant run pump) and fired based on delta T indicating snow. Never used it tho...
    There is another company in Colorado Springs that makes one, but have not used it, and if memory serves me correctly, it too is a slab sensing device.
    ME
  • Dave H_2
    Dave H_2 Member Posts: 621
    Remote Snowmelt Sensor
    I have used these in the past when the slab sensor was forgotten. (Concrete just cures way too quickly!!)
    ETI makes a sensor that does not mount in the snowmelt area, but you don't mount it on the ground. It has a moisture sensor and an air  temperature sensor.
    THe LCD-1 or 3 works just great
    Dave Holdorf
    Taco, Inc
  • Mpj
    Snow melt
    Thank you for the responses. I will check out those products this week.
  • Mpj
    Snow melt
