radiator pipes
jarv
jarv Member Posts: 10
just added a new hardwood floor,now the radiator is to high to connect . Do they make a braided flex hose/ fitting for steam that i could use?
  • kcopp
    kcopp Member Posts: 4,628
    Aaahh...
    that would be a no. Best bet is to pull the riser pipe out of the fitting below and put in a longer nipple. of cut and re-thread a nipple in. Not so simple.
  • Abracadabra
    Use a pipe extension
    A pipe extension piece may help.  If it's too tall, you may have to support the radiator up higher. Hardwood flooring is about 3/4". This thing might extend you about 1-1.5" depending on the pipe size.
  • jarv
    Aaahh
    Thank you , I knew it couldn't be that easy! I was hoping, the riser is between my ceiling and the floor ,Not looking forward to this project, but it must be done .Thanks Again jarv.
  • jarv
    pipe extension
    Thank you for your input.
  • crash2009
    crash2009 Member Posts: 1,478
    edited December 2011
    How about
    Take the valve off the riser, then use a 1" nipple extension.  Also known as a street coupler or a pipe stretcher.  Search the wall for street coupler for more information.
  • jarv
    1 in pipe nipple
    Thank you for your help ,this would be alot easier !! jarv.
  • peteboy
    peteboy Member Posts: 18
    try this
    How about an extension coupler. Go to your plumbing supply house and ask for one. I had the same problem when i retiled my master bathroom. It worked for me.
  • Charlie from wmass
    Charlie from wmass Member Posts: 4,422
    Can the radiator be slip away from the valve?
    If you have room you can remove the Spud from the radiator and use 2 street 45's to off set down to the valve height if the extension is too long.
    cell # 413-841-6726
  • jarv
    extension
    Thank You
  • jarv
    2, 45's
    Thank you i think i might try the extension.
