need help
savion
savion Member Posts: 3
if its on my boiler why cant i find it to buy this is crazy crazy i need help do i have to replace my boiler all because of this part crazy
  • Terry O
    Terry O Member Posts: 67
    you might...
    have better luck posting this under the "main" section.
    Terry O
  • richardplace
    richardplace Member Posts: 10
    boiler part
    Can you post the name and/or part number.I can't quite make out the nomenclature on this flanged part. It appears to be a hot water system and this could be a flow control valve or an air separator (it appears to have a 3/4" nipple and cap on top of it). If that nipple & cap is on of it it could have used as a manual bleeder.Get those part numbers posted!!!
