need help
savion
Member Posts: 3
if its on my boiler why cant i find it to buy this is crazy crazy i need help do i have to replace my boiler all because of this part crazy
you might...
have better luck posting this under the "main" section.Terry O0 -
boiler part
Can you post the name and/or part number.I can't quite make out the nomenclature on this flanged part. It appears to be a hot water system and this could be a flow control valve or an air separator (it appears to have a 3/4" nipple and cap on top of it). If that nipple & cap is on of it it could have used as a manual bleeder.Get those part numbers posted!!!0
- 86.9K THE MAIN WALL
- 57 Biomass
- 109 Chimneys & Flues
- 5.7K Gas Heating
- 105 Geothermal
- 70 Pipe Deterioration
- 975 Plumbing
- 6.3K Radiant Heating
- 386 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
