maytag stove with gas log
ed wallace
Member Posts: 1,612
in Gas Heating
have a customer in East Boston who does not have central heat the heat is off the stove the Johnson control gas valve for the gas log is not operating there is gas getting to the gas valve but not coming out of it could it be pilot generator or gas valve?
You need to take some
millivolt readings to determine if it is the gas valve or generator or some other resistive cause in the circuit. Does the pilot stay lit? While you are at it clean the pilot.0 -
pilot will not light when red button is held down no gas flows through the johnson control so I cannot even light the pilot light0 -
What are the numbers
on the Johnson Gas Valve? Do you even have gas to the valve? Are other gas appliances working? Is this natural gas or propane?0 -
Hi Tim the stovetop and oven work fine there is gas to the johnson control thru the smaller of the 2 gas lines from the control knob on front of the stove the numbers I was able to find read AR4JG418200 also says lsa 5PSI10
- 87K THE MAIN WALL
- 115 Chimneys & Flues
- 107 Geothermal
- 983 Plumbing
- 389 Solar
