permit for fluepipe replacement
Paul_69
Member Posts: 251
in Oil Heating
has anybody heard of a firedept. that wants a permit pulled in mass.when you are replacing fluepipe on exsisting furnace,i had a customer say to me that when i am replacing their smoke pipe the fireman who came to the home for something else said i am suppose to file a permit just like for a new oil line upgrade or furnace replacement, i am a contractor and never did this for any jobs before.
absolutely not
no permit is required to replace smoke pipe. Just follow code for smoke pipe clearances/pitch, and screws per joint. You are not altering the equipment, only maintaining the original install. Call him on it, and tell him to produce the CMR for it.0 -
flue pipe
i will thx. bill. i thought he was nuts.0 -
any time paul
There are a lot of inspectors that interpret code in a strange way to say the least. I know George was going state wide to try and educate some of the, but there are some that know it all, and don't read the CMR as it was intended. Just be civil to the inspector, and ask him to prove you wrong. If that doesn't work, call the state's fire marshall's office about it.0 -
can you
imagion how busy he would be if he had to check every piece of smoke pipe replaced?0 -
for a small fee
he could check filters, strainers, and nozzle replacements too0 -
Flue Pipe Permits:
Don't laugh, Bill, the cities and towns have found that the building departments are cash cows for untapped revenues. There was a time in the Commonwealth, where the law stated that cities and towns could only set fees high enough to cover expenses. Now, it seems that the law was repealed when no one was looking. Now, towns have raised fees, and all fees go into a general fund to be used for expenses that have no relation to running a building department.
How much money was raised by that stupid sheet metal contractors license?0 -
For quite a while Ice
The state sets the minimum fee, and the towns/cities can go from there, and the prices are all over the place to pull a permit, but code is code. New install, smoke pipe must meet all requirements, but replacing rusty, etc pipe requires no new permit of inspection. I know, the sheet metal license. Now there's another thread in itself. If abandoning the permitted venting means and altering that, then that is a horse of a different color.0 -
altering
is the flue pipe replacement considered altering the oil burner?? well at least i told the fire dept. i was filing the permit for the new oil line i installed not the flue pipe. he can look at it all he wants but its pitched right protected with fire shielding where its close to wood and he should appreciate the effort, because for 20 yrs since home was built the pipe was kissing wood walls!! and was inspected!!0
- 87K THE MAIN WALL
- 115 Chimneys & Flues
- 107 Geothermal
- 983 Plumbing
- 389 Solar
