Steamed Up Boiler Room
plumb1
Member Posts: 1
Commercail vacuum steam system. Re-located all feed & return lines 4" into wall with no re-design of system. When return lines enter the boiler room they go into an open sump pit in boiler room and then pumps back to boiler.
Customer complaint - boiler room fills with steam and this never happen prior to replacing main trunk feed & return lines.
Easy one
BAD traps.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
