Delavan nozzle problems...
STEVEusaPA
Member Posts: 6,505
in Oil Heating
Just throwing it out there. Has anyone had any problems with Delavan nozzles purchased in the month? Seems like I had a bad batch. Had to replace 4 .85X80A's, that were all installed from the same purchased lot. These nozzles were just installed during the annual tune-up. There have been other hollows, and a few solids, some I installed, fired up the unit, nozzle no good, then replaced with same nozzle from another batch, fired fine.
I've had a few bad new nozzles before, but a this seems excessive. Any one else see anything similar?
Thanks
Thanks
Will keep an eye out.
Thanks Steve. I haven't, but will keep an eye out. We are still working off nozzles from a mid summer shipment. Recent order came in Friday.
Thanks.0 -
I'll also keep an eye out
They do have a 30 day warranty, so by all means turn them back in. If you are out of warranty, then at least bringing it to someone's attention will let them know that a problem exists. Most just change the nozzle, and heave the old one into the trash or brass pile, and manufactures have no idea there is a problem in the field. I am a squeeky wheel when it comes to that kind of stuff. Just be civil about it, and the reps will generally side with you, or a drop in sales will result.0
- 120 Geothermal
