US Radiator Corp Boiler
GWD1
Member Posts: 1
House was built in 1955 and we suspect that the boiler was too! Never had a problem during the first 18 years, but now have gurgling sounds in the pipes that are inside the ceiling plaster. We have recently noticed water dripping outside of the house through a small copper line coming through the soffet. New boiler will be in near future due to lack of efficiency. Old model has two circulating pumps to send water to front and back of house. Will I need two seperate boilers to accomodate the two piping systems, AND, how do I stop the leak, AND, please help me stop the GURGLING sounds.
Sound liks (no pun intended)
there's a leak in the system and you're taking on lots of fresh water, which releases air when heated. The air makes the gurgling sound. You'll need to find the leak before you do anything else.Retired and loving it.0 -
Also, where is your
expansion tank? Is it up in the attic or in the basement? If you follow the pipe back into the house, where does it go.
Without seeing a design of your system, you should be able to use one boiler. But there are benefits to using 2.There was an error rendering this rich post.
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 849 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
