thermostat problem?
rcrit
rcrit Member Posts: 74
I got a shiny new boiler last week and it's been in the high 60's ever since so I haven't had much opportunity to see it in action.
I heard the burner come on this evening (think jet engine) so I went downstairs to time how long it took to make steam and then get to the end of the mains.
After 5 minutes the burner cut off. It hadn't made steam yet and wasn't under any pressure. The header was starting to get warm but neither of the mains were warm at all.
Is this a case of a confused thermostat? It is an old mercury model and setting the temperate is more art than science. It is set to come on somewhere between 69 and 73. The temperature coil is hosed on it but other thermometers show it is ~72 inside.
I wonder if this is an anticipator issue. With my previous boiler it was set to the max, .8. It is currently around say .4.
  • hosed thermostat
    if part of it is non-functional, then maybe the whole thing is too tired to work properly. the nice thing about the new honeywell digital thermostats is the setup--1cph for steam. there is no longer any fiddling with a tiny lever, while looking at minuscule numbers on a discolored piece of metal. when you feel the need for a little extra warmth, then setting up 1 degree on the readout will do the trick, and the reverse for a bit less warmth.
    make sure that you verify on the package that the thermostat will do steam. most of us like the honeywell visionpro, which is a bit more expensive than the other h/w stats, but does a nice job.
    otherwise, do a search here for "anticipator + honeywell", and you should find many recommendations for the setting of your old one.--nbc
  • rcrit
    now that you mention it
    As luck would have it I ordered a Honeywell TH5110D1006 this morning.
    Maybe my current thermostat found out about it and is pouting :-)
  • ChrisJ
    ChrisJ Member Posts: 16,742
    anticipator
    My guess is because your anticipator is set so low, it got hot enough to turn the thermostat off before the boiler made any steam.
    0.4 is most likely WAY too low,  0.8 sounds more like what it should be.  I'm currently fighting with the opposit.  I had mine on 0.8 and the termpature shoots past my setting so I just dropped the anticipator down to 0.7.  I guess only time will show what it actually did.
  • Techman
    Techman Member Posts: 2,143
    Antisapation of Antisipator Setting
    Remove the t'stat from the subbase, remove the "w" wire from the subbase, have a pre-formed piece of wire ( 18-16-14-12-10-8-6 gauge ) with 10 loops, with your AMP Meter(everyone has one ,right?) on the 10 loops ,connect one end of the "multiplier" to the "w" wire,connect the other wire of the "multiplier" to the subbase "w" screw terminal. The AMP reading is ,say, 6amp,then set the antisipator to .6. Some systems may have a higher "start" amps ,then it goes down to the normal amps. Then fine tune!
  • crash2009
    crash2009 Member Posts: 1,478
    For sale?
    How old is the old thermostat?  I might be interested in buying.  What is the model # ?
  • ChrisJ
    tweaking
    I ended up putting mine back on 0.8 and now to 1.2A.  The system seemed to stop making steam just as radiators started to got hot.
    I'm wondering if this is why Honeywell said to use 1.2 for steam,  because the anticipator doesn't take time to steam into consideration.
  • rcrit
    model
    It is a Honeywell 822D. It came with the house, I've been here two years
  • crash2009
    Too new
    I'm looking for something old, glass, and brass.
