need help
savion
Member Posts: 3
if its on my boiler why cant i find it to buy this is crazy crazy i need help do i have to replace my boiler all because of this part crazy
you might...
have better luck posting this under the "main" section.Terry O0 -
boiler part
Can you post the name and/or part number.I can't quite make out the nomenclature on this flanged part. It appears to be a hot water system and this could be a flow control valve or an air separator (it appears to have a 3/4" nipple and cap on top of it). If that nipple & cap is on of it it could have used as a manual bleeder.Get those part numbers posted!!!0
- 119 Chimneys & Flues
- 76 Pipe Deterioration
