Carlin G3B Short Cycles
Vince11
Member Posts: 1
in Gas Heating
I just installed a Carlin G3B Gas Burner in my Peerless EC-04 Steam Boiler. It seems to short cycle as of late. I installed this 1 month ago. Any Advice?
What is the thermostat
set on for cycles per hour?
What is the setting on your pressuretrol?0 -
Also
what firing rate (input) did you set it for?
What firing rate did the oil burner use?
Was the burner tuned with a digital combustion analyzer?All Steamed Up, Inc.
Consulting0
- 109 Chimneys & Flues
- 976 Plumbing
- 387 Solar
- 17 Recall Announcements
