Carlin G3B Short Cycles
Vince11
Vince11 Member Posts: 1
I just installed a Carlin G3B Gas Burner in my Peerless EC-04 Steam Boiler. It seems to short cycle as of late. I installed this 1 month ago. Any Advice?
  • Tim McElwain
    Tim McElwain Member Posts: 4,657
    What is the thermostat
    set on for cycles per hour?
    What is the setting on your pressuretrol?
    Steamhead Member Posts: 18,205
    Also
    what firing rate (input) did you set it for?
    What firing rate did the oil burner use?
    Was the burner tuned with a digital combustion analyzer?
    Consulting
