just a thought
Just a thought, Would an annode rod keep a boiler block from rotting out? Say if i took out the plug on the return side im not using , install a bushing, then an annode rod,  what would happen.
  • ChrisJ
    ChrisJ Member Posts: 17,068
    edited November 2011
    Hmm
    I'm curious too.
    These are installed in water heaters for this reason, why not a steamer?   Although water heaters don't have any air in them so perhaps its a completely different problem.
    An anode will not stop air from attacking the iron. :(
  • Tim_Hodgson
    Tim_Hodgson Member Posts: 60
    I have several
    large commercial boilers with a 2" x 6" anode connected to a 2 1/2" plug mounted in the mud leg. If it works for them, why not you.
    Good luck,
    Tim
