just a thought
kevin_58
Member Posts: 61
Just a thought, Would an annode rod keep a boiler block from rotting out? Say if i took out the plug on the return side im not using , install a bushing, then an annode rod, what would happen.
Hmm
I'm curious too.
These are installed in water heaters for this reason, why not a steamer? Although water heaters don't have any air in them so perhaps its a completely different problem.
An anode will not stop air from attacking the iron.
I have several
large commercial boilers with a 2" x 6" anode connected to a 2 1/2" plug mounted in the mud leg. If it works for them, why not you.
Good luck,
Tim0
- 114 Geothermal
