AO Smith Effex Atmospheric Gas Water Heater?
exm
exm Member Posts: 1
Hi,
I have an old chimney vented gas water heater and I'm considering AO
Smith Effex GAHH-50 Atmospheric Gas Water Heater, since it's from a
respectable brand with a 0.70 EF. However, I am not sure if atmospheric
requires extra plumbing but it looks like it does not.
My questions:
- Does anyone has any experience or thoughts about this model?
- Can this model replace my existing chimney vented gas water heater
without any additional plumbing or vent installation? Initially I was
looking at the Vertex line but most plumbers are quoting over a $1,000
for installation of the outside vent, so I want to use the chimney.
This looks like an affordable solution
Thanks!
FYI... Here's the AO Smith link
<a href="http://www.hotwater.com/water-heaters/residential/conventional/gas/effex/">http://www.hotwater.com/water-heaters/residential/conventional/gas/effex/</a>
  • Tim McElwain
    Tim McElwain Member Posts: 4,656
    Atmospheric simply means
    it gets its air for combustion from within the room it is installed in. It is not typically a problem with gas piping as long as the pipe is sized correctly.
    You may however have a problem with the chimney depending on its age and whether it is lined or not. Is there any other equipment vented into the chimney? Modern appliances today require installation into lined chimneys.
