NEW YORKER BOILER w/ aux. system
bob young
bob young Member Posts: 2,177
using a new yorker steam boiler with its limited available tappings , what is best piping configuration for baseboard aux. hot water loop off base of boiler. . any other option besides taking supply from probe low water cut-off tapping & substituting # 67 float low water cut-off with gauge glass connections.
  • Rod
    Rod Posts: 2,067
    BUMP
    Thought I'd bump this back to the front of the line
  • bob young
    NEW YORKER BOILER w/ aux. system thanx rod
    THANX ROD.    main issue is supplying & returning to common mudleg.  short circuit . possibly need alternate  piping solution
  • Mark N
    Mark N Member Posts: 1,144
    Hot water loop
    Can you use a different boiler? Or is this one already installed. Click on the systems tab choose Hot Water and then Condensate hot-water heating. Read through that article and it shows a way to accomplish this through the mud leg.
  • Rod
    Rod Posts: 2,067
    Hot Water Condensate Zone with Limited Boiler Ports
    Hi Bob-  I was thinking about the problem of limited boiler ports and HW loops and remembered seeing a piping diagram to deal with this. It's attached below. It is in the Systems Section at the top of this page under Hot Water and Condensate Hot-Water Heating. Here's a direct link:
    http://www.heatinghelp.com/article/330/Condensate-Hot-Water-Heating/76/Condensate-Hot-Water-Heating-FAQ
    I don't know if this would work any better than what you are proposing but thought I would bring it to your attention if your weren't already familiar with it.
    - Rod
