NEW YORKER BOILER w/ aux. system
bob young
Member Posts: 2,177
using a new yorker steam boiler with its limited available tappings , what is best piping configuration for baseboard aux. hot water loop off base of boiler. . any other option besides taking supply from probe low water cut-off tapping & substituting # 67 float low water cut-off with gauge glass connections.
BUMP
Thought I'd bump this back to the front of the line0 -
NEW YORKER BOILER w/ aux. system thanx rod
THANX ROD. main issue is supplying & returning to common mudleg. short circuit . possibly need alternate piping solution0 -
Hot water loop
Can you use a different boiler? Or is this one already installed. Click on the systems tab choose Hot Water and then Condensate hot-water heating. Read through that article and it shows a way to accomplish this through the mud leg.0 -
Hot Water Condensate Zone with Limited Boiler Ports
Hi Bob- I was thinking about the problem of limited boiler ports and HW loops and remembered seeing a piping diagram to deal with this. It's attached below. It is in the Systems Section at the top of this page under Hot Water and Condensate Hot-Water Heating. Here's a direct link:
http://www.heatinghelp.com/article/330/Condensate-Hot-Water-Heating/76/Condensate-Hot-Water-Heating-FAQ
I don't know if this would work any better than what you are proposing but thought I would bring it to your attention if your weren't already familiar with it.
- Rod0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
