Pipe Rusting and Residue GULP "Give it to me straight Doc"
Breez
Member Posts: 8
Have a "mature" American Standard furnace that has a rusting c<span>orrosion that I have noticed leaves rust flakes from the pipes where it enters into the furnace. Am I looking at a furnace replacement or can the pipes be replaced? If the latter is this very costly? Thanks</span>
Hard to tell
Shedding rust scale is something steam pipes just do. They're mild steel, they get hot, and they expand and contract, so they always leave a shadow of fine rust flakes under them.
But what I'm seeing in those pictures is seepage. It looks like some of the threads weren't sealed throughly and over the years, water has leaked out and caused rust to accumulate.
Personally I wouldn't want to try to get those pipes out, but as long as they aren't dripping on the floor, I'd leave them alone. If they eventually have to come out, you're just looking at a bad day, not a new boiler. There are some tricks to getting large pipe out of old boilers, and when the time comes there are people here who can help you, but if you don't feel up to it, call in a professional who can replace the pipes and give the boiler a thorough inspection and cleaning.Just another DIYer | King of Prussia, PA
Thanks That Eases My Mind
Good to hear. I imagine I would see small droplets of water if the nipple was starting to breach and I would have ample time to call in a professional.0
