Heating Alert! Fulton
DanHolohan
Member, Moderator, Administrator Posts: 16,686
<a href="http://www.heatinghelp.com/article/371/Fulton/2225/Fulton-China-Expands-Into-Global-Water-Tube-Boiler-Market">http://www.heatinghelp.com/article/371/Fulton/2225/Fulton-China-Expands-Into-Global-Water-Tube-Boiler-Market</a>
Retired and loving it.
100 ton/hr of steam
I wonder how long it would take to start a boiler like that before it starts to steam. A day? Two days?8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
minutes perhaps
You have to remember a couple things...
That boiler is going to have one helluva burner with a very high firing rate.
In a water tube boiler, the water content in comparison to the firing rate is relatively low. The mass of the tubes is also realitively low.
I suspect that thing would produce steam in an amazingly short period of time!Dave in Quad Cities, America
http://grandviewdavenport.com0 -
In that case..........
I hope they have a low water cutoff!8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
I'm betting...
that they have NUMEROUS water sensors on that boiler...
I'll bet is has one heck of a deaereation system too....
Fulton invented the steam boiler didn't he? And Watts the relief valves? And Gil Carlson the BTU :-)
ME0
