Heating Alert! Fulton
DanHolohan
DanHolohan Member, Moderator, Administrator Posts: 16,686
<a href="http://www.heatinghelp.com/article/371/Fulton/2225/Fulton-China-Expands-Into-Global-Water-Tube-Boiler-Market">http://www.heatinghelp.com/article/371/Fulton/2225/Fulton-China-Expands-Into-Global-Water-Tube-Boiler-Market</a>
Retired and loving it.
  • 100 ton/hr of steam
    I wonder how long it would take to start a boiler like that before it starts to steam.  A day? Two days?
  • Dave in QCA
    Dave in QCA Member Posts: 1,806
    minutes perhaps
    You have to remember a couple things...
    That boiler is going to have one helluva burner with a very high firing rate.
    In a water tube boiler, the water content in comparison to the firing rate is relatively low.  The mass of the tubes is also realitively low.
    I suspect that thing would produce steam in an amazingly short period of time!
    Dave in Quad Cities, America
    http://grandviewdavenport.com
  • In that case..........
    I hope they have a low water cutoff!
  • Mark Eatherton
    Mark Eatherton Member Posts: 5,875
    I'm betting...
    that they have NUMEROUS water sensors on that boiler...
    I'll bet is has one heck of a deaereation system too....
    Fulton invented the steam boiler didn't he? And Watts the relief valves? And Gil Carlson the BTU :-)
    ME
