Burnham mm4-104
lchmb
lchmb Member Posts: 2,997
Curious, had a unit go down over the weekend. The inducer motor has failed on this unit. I've been told this part is no longer available? Has anyone else run into this? Hate to swap a boiler out for a motor....
  • CMadatMe
    CMadatMe Member Posts: 3,086
    Not True
    MM's are still avail. I just quoted one. Burnham builds them as needed provided they have all the parts for them in stock which they do.
  • lchmb
    edited November 2011
    Chris
    The unit I have is one of the older unit's and they say (supply house) not available? ..I'll have to check with Burnham direct I guess..I hate to cost the customer more than need be..
    thanks for the input..
  • CMadatMe
    You
    Should call them if they don't have I believe that was a Fasco motor. Try this..
    http://www.fasco.com/pdf/FascoDraftInducerCrossReferenceGuide.pdf
  • lchmb
    Thanks
    Chris much appreciated!!
  • CMadatMe
    If That
    Doesn't work try this.
    http://www.fasco.com/documents/pgs068-095.pdf
  • lchmb
    ok
    Burnham was contacted and this unit is the first generation, 18 years old and the blower is no longer available. I could pay a lot to get one made but not sure how long...It goes to the dumpster tomorrow....
  • CMadatMe
    That Sucks
    I wonder what design changes were made that the current blower wouldn't work?
  • lchmb
    direction
    they changed the direction the unit was installed and the opening and plates by the look of it. Also the way it attach's to the cabinet.
