Calling for heat
madmatts
madmatts Member Posts: 3
The furnace seems to be receiving a call for heat when the house temp does not warrant the action.  Sequence starts up but shuts down almost immediately.  Will do this repeatedly.  When the need for heat is warrented, system operates fine.  Any suggestions for a remedy?  I am not by any means an HVAC wizard
  • Does the boiler
    have a tankless coil?  That is, does the boiler provide domestic hot water as well as heating hot water?
  • madmatts
    Calling for heat
    forced air not hot water system  sorry for not mentioning that earlier
  • madmatts
    Calling for heat
  • billtwocase
    billtwocase Member Posts: 2,384
    Thermostat
    What type do you have? Sounds like it is no good
  • billtwocase
    Thermostat
