gas line test pressure
ChrisJ
Member Posts: 17,070
in Gas Heating
I just installed a new gas line in my house and was told I must pressure test it for the inspector. I have this all set up but am curious about the test pressure.
It seems most guys say to test it at 5 psi. Why is this? Why not go higher, say, 10 - 15 psi? Wouldn't this make finding any leak even a small one faster?
testing
Make sure to disconnect your appliances in case a shut off fails. As far as pressures, the black iron can handle any pressure but most use a rogers guage which has a hand pump on it. 5lbs will tell you if there is a leak, although nothing say's you cant test it higher...Dont forget the system only run's on 11" water column (propane)....0 -
Pressure test
I don't know what your inspectors want(hes the boss) but, here in Minneapolis and St. Paul its 25lbs for 24 hours or 100lbs for 1 hour. What ever kind of pipe your using can handle that, or it shouldn't be used.
-Andy0
