Entran III
SMI
Member Posts: 1
Wanted to know if anyone knows about a start of a class action for Entran III Thx Tim
If any one would know....
It would be David Black, an attorney that I worked with on the E-2 cases..
303-291-2300
If you or anyone you know are experiencing any issues with E-3 David would like to know about that as well.
ME0 -
not sure what the product I have is.
I'm obviously a little late in this thread, but I live in Alaska, and purchased a house about 8 years ago. The house was built in 1984, and has about 3000 sq ft downstairs below grade slab with radiant floor heat, along with an oversize 3 car garage. This has been a nightmare keeping the system running. We have determined that there are multiple leaks in the slab, causing a large amount of air getting into the system. I am bleeding the boiler every other night to keep the pumps from burning up. I've learned what the whistling sound means after replacing 2 pumps at $350 each and get right to bleeding the air out as soon as the noice is present. I plan on replacing the boiler and the contractor is concerned that the tubes are not oxygen barrior and may have some effect on the stainless steel jackets. I've attached a picture of the manifold. I don't know if it is Entran, Onyx or some other brand. Would appreciate some knowlege on this.
Thanks
GDH0 -
B.E.S.I.
Bio Energy Systems Inc. Long gone with no trace...
And your assumption is correct, no oxygen barrier on the tubing. I believe it is an EPDM rubber, which over time will harden and eventually fail. Suggest you start looking at total system replacement...
ME0 -
Hoser
Saw some Entran 3 today.
I warned the customer and told them I would get back to them. I am having trouble finding info on it.
It was added to a 1950s copper in ceiling / in floor house. We put a new boiler in this summer, I think my boss deserves a little grief for not adding an air sep, and an auto fill.
I'm wondering with the lack of O2 barrier, am I going to be back there every 2 months trying to purge all the air out with those 60 year old LEAKY globe valves all over that house?
-Andy0 -
E 3 actually had an o2 barrier...
It was made of EVOH, just like all the PEX people used. The problem with all of these hoses is that the oxygen travels a path that is parallel to the barbed fitting. It won't pass thru the walls at a right angle. The more tube circuits, the more barbed fittings, the greater the potential for Oxygen diffusion. And when it starts degrading (oxidation/embrittlement), which it will, the rubber gets brittle and sounds like Rice Crispies when moved.
Bad news when it does that...
Good luck with your venture.
ME0
