close call
a customer called at 11:30 pm and said these exact words.  My boiler is glowing cherry red and I think there might be something wrong
  • gerry gill
    gerry gill Member Posts: 3,084
    hehehe
    he thinks??
    gwgillplumbingandheating.com
  • steamy ray vaughn
    steamy ray vaughn Member Posts: 27
    close call
    The boiler actually cracked the concrete pad it was sitting on and melted the transformer
  • steamy ray vaughn
    close call
  • steamy ray vaughn
    close call
  • lchmb
    lchmb Member Posts: 2,997
    WOW
    Scary stuff...think I'd pull the plug and run...
  • steamy ray vaughn
    close call
    Went there the next morning the safguard 400 did not shut down the burner and the 47-2 lwco feed combo float was laying on a mountain of mud.  Cut in a bypass line to see if the vessel would hold nodice.  the returns where 90% plugged.  He has no idea how lucky he really was.
  • Dave in QCA
    Dave in QCA Member Posts: 1,806
    Scarey Stuff
    Run away dry firing is always scarey.  Makes me wonder why no one ever thinks of mounting an acquastat set at 240F.  It would shut the boiler down before any damage was done.  Of courese, the cast might still crack, but there were be better protection against a building fire.
    Dave in Quad Cities, America
    http://grandviewdavenport.com
  • ChrisJ
    ChrisJ Member Posts: 17,390
    edited October 2011
    That is the
    first time I ever felt a triple post was valid and even necessary.  Kind of showed some emotion even tho it was a mistake..
    I'm about to install a Safegaurd 400 on my own boiler.  Is it common for them to fail like that?
  • Dave in QCA
    Agree!
    with you on the triple post!
  • steamy ray vaughn
    close call
    funny thing that the customer forgot to mention on the phone was that he had replaced the transformer prior to putting it into service.  He told me that he is a car mechanic. I don't think I'll be taking my car to him in the near future
  • Dave in QCA
    radiator flush?
    At least I would not let him to a radiator / coolant flush!
    By the way.....    qca= Quad Cities??
  • steamy ray vaughn
    close call
    yep Quad Cities
  • Dave in QCA
    Howdy
    Nice to see someone on here from home.
  • steamy ray vaughn
    hello
    hello back at ya.
